Vapour barrier and Ecotherm insulation
22 Apr 2020
Advice needed regarding a vapour barrier. I've removed old plaster back to stone in an 1830 house (it has a damp issue from a chimney breast which I'm addressing), I want to VB, batten at 600mm centres, insulate between and fix with fixings and then screw PB to the battens and skim.
But I've been told just to use visqeen, I'm wondering if permaSeal is a better option or if that's an over kill.
Also if I VB first then batten and then fix the insulation with 8mm plastic fixings how do I seal the holes I create in the VB from the fixings and screwing the battens to the wall, am i just over thinking it, or is there a better solution.
I've already bought the foil backed insulation so a can't change my mind about that.
Vapour barrier or DPM? The two are distinct and prevent moisture migration form differing directions.
The few fixings from the battens will not affect the performance of the DPM.
You would not fix the insulation or add any further penetrations of the membrane.
Consider spacing the battens at 400 or 450 centres to avoid excessive bounce or bowing of the boards if the walls are uneven.
Fit the insulation between and over the battens to avoid a cold bridge.
