Advice needed regarding a vapour barrier. I've removed old plaster back to stone in an 1830 house (it has a damp issue from a chimney breast which I'm addressing), I want to VB, batten at 600mm centres, insulate between and fix with fixings and then screw PB to the battens and skim.
But I've been told just to use visqeen, I'm wondering if permaSeal is a better option or if that's an over kill.
Also if I VB first then batten and then fix the insulation with 8mm plastic fixings how do I seal the holes I create in the VB from the fixings and screwing the battens to the wall, am i just over thinking it, or is there a better solution.
I've already bought the foil backed insulation so a can't change my mind about that.
