- Joined
- 11 Jun 2016
- Messages
- 339
- Reaction score
- 17
- Country
Cheers crank39, your right. Can't see much inside the hole's, what should i be looking for?I suspect that might already have some hinges fitted, also take that plate off and you might find 3 holes, 2 are fixing holes for a handle with a centre hole for the spindle, try it
Managed to get photos from inside frame, looks ******ed to me.Theres a mechanism in there by the look of the middle hole, can you see a square drive in there, put in a wide flat bladed screwdriver in there and see if it'll turn one way or the other
Apologies for not getting back sooner. I take it the only way to find out which one it is, is to get the window open & have a look or is there another way of finding out which one?That'll explain why is closed... the mech is broken and rather than get it fixed they've just taken the handle off and trimmed over it. Had to say if it's an espagnolette or a shootbolt... either one are openable depending how rusty/seized it is... and hopefully with little damage to the frame
Unfortunately not, every other window had been replaced before i moved in.Only of you have other windows from the same supplier, they should be the same
Condensation is caused by warm air hitting cold surface. It is cold because these windows are hollow. There's only a few millimetre of pvc keeping heat in. All but the inside surface of the glazing are exposed to outside temperatures. Old timber windows don't suffer the same, but they rot. On my timber windows, only the outside surface of the glazing is exposed. The glazing edges are buried and sealed in frames of solid materials.Also would it make much difference to condensation in this area, being able to have a window that you can open?
