Sure, it's an outflow, not an overflow. Apart from the vent pipe there is no overflow.I think you'll find that overflows the world over are designed to cope with inundation.
It's actually an outlet, but to keep it simple I used the word overflow.
That probably requires digging (after some searching). Whereas separating the guttering is much easier.One of these can soon sort out the problem, just bung the right sized one in the neighbours feed and tighten it up.
Can be left in or removed should they finally decide to play ball.
The vent pipe is not an overflow.Apart from the vent pipe there is no overflow.
That's what I said.The vent pipe is not an overflow.
However if the tank is ever inundated, and the water level reaches the top of the vent, that vent becomes an overflow.Apart from the vent pipe there is no overflow.
What happens when the leachfield is contaminated by solids?As I said previously, the outflow is designed to cope with heavy flow.
If you know exactly what will hapen in those scenarios, why don't you share your knowledge with us?I know exactly what will happen in all your scenarios,
Since you asked; I have a degree in wastewater treatment. I also have first hand experience of septic tanks. I prefer to read these posts without offering advice as it amuses me to read some of the utter tosh that people post.
And, on the few occasions that I have given advice, or voiced an opinion, there is always someone who knows better and I know from what they have written that they don't know what they are talking about.
That'll be a no from you, then?If you know exactly what will hapen in those scenarios, why don't you share your knowledge with us?![]()
So we are agreed, the OP septics tank is in no worse a situation than it has been for the last X years and there will be no additional operational costs incurred due to the neighbour not sending his foul drainage to the septic tank (in fact on a simple pro rata calc average yearly operational costs will be halved) and any rainwater input (steady or inundated) will not add anything to these costsOf course, it could all happen anyway, but it's more likely to happen if there are more homes discharging into the tank, whether it be brown water or rain water.
Except, of course brown water flow tends to be little and irregular. Whereas rain water can be a deluge, persistent and often.
Yes, that's a no, as I explained in my last paragraph.That'll be a no from you, then?![]()
Except the elephant in the room. There will be no additional operational costs, but they are now the responsibility of just one person, not two.So we are agreed, the OP septics tank is in no worse a situation than it has been for the last X years and there will be no additional operational costs incurred due to the neighbour not sending his foul drainage to the septic tank (in fact on a simple pro rata calc average yearly operational costs will be halved) and any rainwater input (steady or inundated) will not add anything to these costs
I'd just split the gutter, and if your contractor can easily block off their pipe, then do so.Up until a month ago my semi detached cottage shared a septic system with neighbour. They have installed their own septic system leaving me with the old system. However they have not been fully decomissioned from the old system as rainwater still going into it (it's an old system). They refusing to contribute to shared system however it is being part used and have told me rainwater is separate which is clearly not due to the gutters and downpipes! With this in mind can i split the gutter? My contractor has said they can block off the drains so that it is 100% separate but rainwater from roof still a concern and as i am having new system built i dont want to have to pay to deal with next doors drains/rainwater
Then as you have no intention of offering advice, nor answering any questions about possible scenarios, in your specialist area, why have you involved yourself in this thread?Yes, that's a no, as I explained in my last paragraph.
I think you'll find that I explained that in my first paragraph in post #21.Then as you have no intention of offering advice, nor answering any questions about possible scenarios, in your specialist area, why have you involved yourself in this thread?
So you've been amusing yourself?I think you'll find that I explained that in my first paragraph in post #21.
...I prefer to read these posts without offering advice as it amuses me ...
I accept that one person is now paying for empty but it will occur at twice the original period so overall its cost neutral costExcept the elephant in the room. There will be no additional operational costs, but they are now the responsibility of just one person, not two.
Fair pointSo you've been amusing yourself?
Is that another word for trolling?
And it still doesn't answer why you decded to become involved this time. You've offered no advice, refused to explain what you think when the scenarios I've presented occur, nor offered anyone the benefit of your specialist knowledge.![]()
