- Joined
- 24 Nov 2009
- Messages
- 28
- Reaction score
- 3
- Country
Hi All
My central heating controls do not work because, I think the actuator does not work
I can manually move the 3 position 'tap' (normally driven by the actuator) to get hot water or central heating but the electronic actuator seems stuck so the thermostat has no effect making controlling the heating impossible!
If I remove the actuator from the valve, I can feel it vibrating ( presumably as the motor turns) but the spindle that engages with the the 3 way valve doesn't move. I cant even move it by hand. Is there a way of freeing up the spindle?
Or any other suggestions as to how I might fix this thing?
Thanks for any (reasonable -
) suggestions
