- Joined
- 13 Oct 2023
- Messages
- 11
- Reaction score
- 1
- Country
Again replying to sureitsoff. The fan clicks on & off itself due to humidity levels (our house is brick & lime built in 1896. It has lime plaster walls too, so it gets quite high humidity levels). It keeps going until it decides to stop, then the timer kicks in & keeps it on for another 15 minutes. This is functioning fine & just as it should. The switch is there in case me or my Mrs wants to put it on for whatever reason. When we switch it off, again the timer will kick in & it will continue to run for a further 15 minutes.
Ah, OK, so the little blue wire on the back of the switch connected to the empty neutral terminals just needs to be linked with the wago connector with the neutral wires. Is that correct, or should I join the neutral wires in the back of the switch rather than in that wago connector? I'd guess both methods would be the same & I'll have to open it up again to see if the LED wire is removeable. When you confirm which is best, or if either of these methods will work I'll give it a go & see if it works. Thank you for your advice.
EFLimpudence if I did that, then I'd lose the kill switch labeled fan isolator (yes I know that the fused spur does the same thing, so I have two kill switches), but I can reach the fan isolator & not the spur. I need a ladder to reach the spur, but can reach the isolator swich on tip toes. The switch is easily accessable. Also, if I sell the house, it will be clear to whoever buys it what each of these switches are for. I also need (due to my autism) to have things match other things in the house, so wouldn't be happy to ditch the fan isolator. I think sureitsoff's solution is the way to go for me, but thank you for taking the time to offer your advice.
I appreciate everyone who has given their valuable time to answer my questions. Thank you all. I'll post a pic when the LED is working.
