I am trying to redo a railway / Xmas village scene diorama. I started a few years back for my grand daughter, but although the train set was reasonably expensive it is too fragile, and now a bit rubbish, so want to dump that and use a Hornby set.
This one will run around the Xmas tree, so I don't want the model houses etc to be individually switched. I also do not want to spend a packet where I can save £££'s.
My idea is to buy some small round push button switches that can be mounted directly onto the base board. I will then run flex to the individual displays to power and switch from the front of the display. I may have to replace some of the lamps and lampholders.
If I find there are people that can help, and have an interest in modelling, I may return with more questions, but for now:
I thought if using one r two the many plug in appliance adapters that are kicking around. I intend to cut of the outlet plug and connect to a terminal strip or bus bar. From that I will wire to the switches and then to groups of the models - so pushing one switch will power several individual units. I will have to look at the amperage of these lights, and things like Ferris wheel but what are the implications if I don't get a perfect match? I seem to recall that it is okay to use an adapter that is significantly higher output than the demand , but not the reverse.?
Is there anything basically wrong with my idea?, and I would welcome any (constructive) comments
Thanks for reading
Thanks for reading
