Which stages of the build do building control need to check?
15 May 2013
I've got planning for a garage extension but before I get into the project does anyone know at what point building control need to inspect the work carried out? Trench depth? Etc etc.
Thanks for any pointers
When you engage them, ask them when they want to visit. There will be more than one and generally it's whenever you're just about to cover up something they have an interest in seeing; before you put concrete in your trenches, before you cover your insulated walls in plasterboard etc
This saves you having to undo work i.e. dig holes beside foundations so they can see depth and soil/take plasterboards off
Also helps to take loads of pictures during a build so if there is something they suddenly retrospectively decide they want a look at you can just whip your phone out..
Thanks for your reply. That gives me a fair idea of what to expect. I'll give them a call
Nowadays, building control asses the build and tell you what they need to check and how many visits they will make. Ask for more visits and they will charge extra for them.
Have you had an email, showing the latest changes to BC inspection format (October 1st 2023)? Client/Designer/Contactor responsibilities have now been updated.
OK so we called them and they said they'd be there Monday. I dug the trench dug by hand as I didn't want the weight of the digger to mess up the block paving.
Does the trench sides need to be smooth? Slicing the mud off the sides makes me want a kebab
Sides should be more or less vertical and straight, with a consistent minimum width throughout. The bottom level, flat and not soft.
Thanks Woody. Unfortunately the trench keeps filling up with water so it's hard to get the bottom dry. I have some hard-core I could tamp into the bottom of the trench?
They need to check the depth, so adding anything is counter productive
