That is a very good idea, presumably the batteries would last a good while, given the low demand?
Until the transformer inter winding insulation breaks down. Happens very very seldom but the possibility should not be ignored.
Good point, but most razor sockets are fed from isolating transformers anywayShould I be concerned, given that I sometimes shave with the electric razor plugged in?
As before:That is a very good idea, presumably the batteries would last a good while, given the low demand?
If you could utilise a power bank, you would have ample 5V power and it would be easily rechargeable.And with the use of a powerbank, your display wouldn't even need to be plugged in.
If you mean mine, it won’t be terribly exciting. Basic kit with added scenery, for the grand kids.Would love to see pics of the model railway...
IfI can get around to clearing one of my sheds, I would like to do a big one, if the kids get interested .
Most of the fun is in the building, improving and changing it.if the kids get interested .
If you chose to use leds, these run at 2 volts taking about 20mANot sure if I am answering your point, but the actual PSU’s will not be accessible to the kids. The idea is to wire everything under the baseboard, with the only items for the kids to touch (apart from the train itself) being the illuminated rocker switches, and a couple of light switches used where it is not feasible to avoid.
When higher voltage introduced, the led fusesWhat would actually happen to 3.5v / 4.5v / 12v LED’s if they were suddenly introduced to 230v? Bearing in mind the thin wire used to connect
I'm afraid that is a little backwards.When higher voltage introduced, the led fuses
Led that normally ran at 2 volts, I applied 50 volts to it, one went off with a crack
I believe your maths may be slightly out with this oneResistor value for 12 volt supply R equal voltage divided by current. 10/20mA equals 5k ohms. Often 4.7k resistor used
Most of the power supplies we have been talking about have been SMPSU, that don't have an earth connection.Question re secondary on transformer going live. The case or the core would go to earth as would a leg of the secondary winging
