No HW or CH, potential programmer or 3 port value problems :)
You say you have a mid position 3 port valve , so you have a fully pumped system, but your old programmer is set to Gravity, you need to remove the programmer and set it to pumped on the back then put it back on
I can’t seem to see a Gravity / Pumped switch on the back, could it be that this programmer is too old to have one?
Try turning this one 90 degrees anticlockwise...
Thank you I tried this this evening and it worked I can not turn on CH only and the boiler works and the heating comes on :)
So the issue now is only the boiler won’t come on when I have only HW selected. I have retaken the readings from the wires of the 3PV.
Check the cylinder thermostat is receiving voltage from the programmer/ timer, it probably isn't.
Just double checked and it is receiving 240v.
I’ve just noticed there’s a boiler control reset and an element control reset on the cylinder thermostat. Could either of these help?
Check it’s sending 240Vac out on demand too.
You could try the boiler reset ,the other one is for immersion heater.
Have you had immersion on ,is the water in cylinder already heated ?
