You say you have a mid position 3 port valve , so you have a fully pumped system, but your old programmer is set to Gravity, you need to remove the programmer and set it to pumped on the back then put it back on
Thank you I tried this this evening and it worked I can not turn on CH only and the boiler works and the heating comes on
So the issue now is only the boiler won’t come on when I have only HW selected. I have retaken the readings from the wires of the 3PV.
