Hello, I’m new to the group so please be gentle.
Had a builder in recently to do a bedroom extension above existing garage. All done well, however when building control gave visited he has said the insulation layer between garage roof and new bedroom floor is not thick enough. He has said this can rectified by placing 15mm pir board over plasterboard ceiling in garage and taping the joints to provide a vapour control barrier.
My question is suppose is if you use the 15mm pir board as suggested, surely the foil side would go against the plasterboard ceiling so then the extra layer of plasterboard on the 15mm pir can later be skimmed. How do you tape the joints if foil side up as I presume plaster won’t stick to foil if facing downwards? I have seen folks of green plastic that state they are for vcb?
Any advice on how best to proceed greatly appreciated. Thanks guys
