Hi all.
Brand new poster here. We are doing up our first home and removed an old conservatory a few weeks ago which spanned most of the width of the rear of the house.
The house was built in the early 60s. You will see there is what looks like either a pre-stressed or reinforced concrete lintel which spans the back of the house. Not sure if it's just a rectangular shaped lintel or a boot lintel going back where we can't see.
After removing the conservatory we discovered that part of this concrete lintel has been cut near the downpipe where they had attached the conservatory. Not only have they cut part of the concrete but also one of the steel reinforcing bars which runs inside the lintel. The exposed steel looks to have corroded a bit and there is a gap where the bar/rod has been cut of some 6 inches approx.
I can only hazard a guess from where this steel bar is within the lintel that there may be probably two more bars/rods further back in the lintel in tact which are not visible.
We are wondering whether to get a structural engineer to have a look and see what might need to be done to make sure the house has structural integrity going forward.
Any help or advice would be much appreciated. We had very much hoped the house was structurally unaltered dispute this old conservatory and have found this on removal which has left us not knowing what might need to be done.
Thank you.
Thank you.
