Hive Greenstar question
4 Oct 2021
Hi all, I’m not seeing exactly what I need so hoping someone can confirm for me please.
Hive mini single channel diagram and internal board of Worcester Greenstar combo boiler attached.
Can someone please confirm exact wiring as the board doesn’t have the usual LS, NS, etc.
All help very much appreciated.
Cheers
On the PCB you have LNE and next to it are L and N out - use these to the Hive, link from L to Common (1) on Hive, then you have Heating on (3) back on LR.
Fantastic thanks very much. When linking (heating on) back to LR on the PCB, would that be into the heating LR or hot water LR or is it into the heating LR and then add a link / bridge to the hot water LR.
Thanks again.
Hi all, I have had a complete mind block. In reference to the above, I wired in hive as per instructions by CBW and it’s working perfectly, but I didn’t route it through a 3 amp switched spur.
Do I need to do that or is it perfectly fine coming direct from the boiler?
Thanks all.
