Hi guys, quick question, I am thinking of buying vertical column radiators, and it seems some require input on the left and output on the right, whereas some others it shows you can plumb them in almost any possible way (input at the bottom left or right or at the top left or right ). They all also seem to have a "block" at the bottom (I presume to force the flow to travel across the whole height of the radiator) and in some models the block is right in the middle, but on other models the block is closer to the flow.
