Backlight timeout delay on Worcester Comfort II RF controller
11 May 2004
Hampshire
Any ideas what determines the delay on the display backlight?
The light comes on when the temp setting is adjusted (as expected), but sometimes it goes off quickly, and sometimes it stays on for a minute or so, which seems a bit long.
Is the OFF signal sent from the WB boiler, or is it a setting internal to the controller? And is the delay timeout user settable?
Hopefully this is not indicative of a signalling or other major issue. (Note for the uninitiated - this is a wireless timer & thermostat.)
Usually such things are a fixed time, my Vaillant LED backlight is, but the LCD remains on for quite a while longer. In your case, I would guess it remains on whilst adjusting, then remains on until it has sent the new setting, plus received an acknowledgement. Maybe the signal is poor, and it takes a while to get through...
Have you tried adjusting the control, with it nearer the receiver?
Thanks! I will try that, as it's something easily within my control. There's only about 12 feet from boiler to the controller as it is, but there may be signal interference.
BTW - the acknowledgment of the 'demand' signal is the little flame symbol. That doesn't show until the boiler has fired up and sent its reply. On this model the LCD display is permanent. It's the LED backlight that seems to have random timeout delay.
