If a 32A MCB would be adequate, it must be a very low-powered shower. On what basis has the "32A" been decided?I have a Memera 2000 consumer unit but need to upgrade one RCB from 16a to 32a for new shower, how do I remove RCB from unit, it does not seem to want to come out?
What power is the shower?recommended 30a in fitting instructions so thought 32a would do, am I wrong?
Its a 6mil cable previous to shed. Shower is 9.5What power is the shower?
... and what size cable is the circuit wired in ... and what was previously supplied by the (16A) circuit?
It won't "lift" until it is released from the bus bar.so that you can lift it off the rail.
I think this is a 6mil its thick & was for a long run down garden & put in a while back by brother in law an electrical engineer who now has dementia so cant call on him anymore.Its a 6mil cable previous to shed. Shower is 9.5
Did these fitting instructions (and the shower!) come from a reputable manufacturer? As you've been told, a 9.5 kW shower needs at least a 40A MCB.Shower is 9.5
Rather more likely is that is requires a 30mA RCD, which is entirely different from the 40A+ current rating of the device for overload / short circuit protection.recommended 30a in fitting instructions
Yep, your speculation may well be correct.Rather more likely is that is requires a 30mA RCD, which is entirely different from the 40A+ current rating of the device for overload / short circuit protection.
There will be a fire risk if the new MCB is not fitted correctly to the bus bar,
As already advised Get a competent electrician to change the MCB
