Programmer Horstman to Honeywell ST9400C
11 Dec 2015
I'm replacing Programmer Horstman H27XL with a Honeywell ST9400C but having problems with the wiring as the Horstman had 9 connectors and the Honeywell has only 7.
I've attached a photo of the Horstman wiring and a photo of how I've wired in the Honeywell.
I don't think it's heating the water
The central heating works
What have I done wrong?
I have an interconnecting loop over
Thanks Chris,
I did as you said and now I've hot water but no central heating
  • Thanks
Reactions: CBW
Is the heating still on and thermostat still calling for heat?
The heating is still on and calling for heat.
The black wire is still in 4
Mmm. It should be - especially if nothing has changed regarding the black wire.
I can't help but think something else has 'turned off' the heating.
  • Like
Reactions: CBW
Have you disturbed the black wire or has come loose? Photo of changed wiring please
The black wire is securely in place.
I've just put the wiring back as I had it originally in the photo, and as before, the central heating is working but not the hot water
  • Thanks
Reactions: CBW
can you post a photo of the new wiring?
With the wiring as per the attached photo, the hot water heating doesn't work.
The central heating only runs if the hot water is selected to 'OFF'
  • Thanks
Reactions: CBW
Do you know what type of heating system you have?
Despite the modern wiring, might you have a Gravity system?
  • Thanks
Reactions: CBW
