Whicb Proving Unit ?
14 Oct 2023
Decided to buy martindale Voltage Tester VT12.
Can anyone point out a 'good enough' decent GS38 proving unit?
Thanks.
I have a 12 volt 12 Ah jump starter lamp and compressor, it was left to me, it has a 13 amp socket 300 VA, so I use that as a proving unit when required, it is not ideal as it does not ramp up the voltages, a proper proving unit should show the tester will work at 50 volt AC or 75 volt DC i.e. any voltage over extra low voltage must work the voltage tester, be it AC or DC or anywhere between the start of the low voltage range and likely maximum, so should step test both AC and DC.
To be frank the issued proving unit I had was 500 volt AC so rather pointless, as the tester may show all lights 12, 50, 100, 250, 500 etc. But you don't know if any would actually show at 50 volt AC or 75 volt DC so the unit is only to satisfy the safety officer it is really worthless.
I have not yet seen a proving unit that uses both AC and DC through a range of voltages. There may be one. The same applies to tester, must not be able to be switched off, even with discharged batteries, or turned to another function, and must be AC and DC.
However few fit the criteria, and I suspect most can use a multi-meter safely, so in real terms we are looking for test kit to satisfy a safety officer, rather than one guaranteed to do the job.
I have even after testing for dead had a supply been made live by a relay which we had no idea fed the cable in question. Lucky no one hurt, and no damage, but just good luck, and using all the correct equipment did not help.
So we do a risk assessment, we could not trace the cables due to concrete build up, it was a batching plant, so after the event it was decided we could only remove the redundant cables when plant not in use.
Even in a domestic (house) have found a socket connected to next doors supply.
So what is the highest risk, removing screws to gain access to use a tester, or use a non contact tester which could give wrong results? Most will test using a variety of testers, including a neon screwdriver to detect borrowed neutrals. It is true a clamp-on may also find borrowed neutrals, if you can actually get its jaws around the cables.
So in the main proving units are to satisfy some safety officer, so let them select what should be used.
It does show open circuit or the value of the resistance for a good unit
The value of the resistance is irrelevant.
All that is required is open or continuity, which any continuity tester will do.
The resistance measurement feature on the more expensive Fluke models is pointless.
Cheapo tester shows continuity or open. This is element intact or busted.
Expensive Fluke piece shows the actual resistance of the element or open. This is element intact or busted.
You are paying 3x the price just to see the actual resistance of the element in ohms, which is of no additional value in determining if the element is intact or not.
I thought question was about proving unit? Not the tester? However I have found in the past using a proving unit not designed for the tester has caused problems, where the tester has used more power than the proving unit could deliver.
But if a tester can measure open circuit, the big question is can it have the wrong scale selected? Personally I am happy using a multi-meter to test for dead, but am also aware this would not be allowed by some safety officers, only worked in one place where proving units were always used, and it was site pass removed if caught without one at ones side, which in real terms meant the sack.
But the proving unit we had to use only produced 500 volt AC so a bit useless as it did not prove the tester would show over 50 volt AC or 75 volt DC so using my jump starter kit was just as good as the proving unit.
Once you has any other scale selectable other than volts then the tester may be considered not to comply, and it needs to test AC and DC without swapping and range scale switch. This 1703752469114.pnghas been the tester used for years to prove dead, no switches, works AC and DC no batteries. There are LED versions 1703752713973.pngoften sold with the proving unit, that way one is sure it will work.
It does what I need on occasions - which is confirm if the element is ok and has a reading of around 20 ohms ……….
As I stated before that’s enough for basic testing
