My electrician has advised me that my bathroom ceiling light is not IP rated and should be replaced (photo below). It's not above the bath, but about 80 cm away from a point above the closest edge of it. Its base is 2350mm above the ground, which, according to this website https://www.thelightingsuperstore.co.uk/bathroom-lighting-zones is sufficient for it not to need an IP rating. It is, as you can see, rather open. It came with a semi-transparent plastic circular guard, but this was useless as the heat of the lightbulb quickly caused that to disintegrate. So (a) should I replace the light as suggested by the electrician, and (b) as an alternative, can I source a replacement guard to go in there?
Thanks.
Thanks.
