Rad slow to heat up fully
It will tell us that the system isn't wildly out and will only need the minimum of adjustments to get the column heating up properly. If it takes more then a more extensive balancing exercise will be needed.
If they all need to be off and there are only 7 rads then that column has a problem with either it's supply or the rad itself. A 2 year old combi on default settings should easily supply all those rads albeit with a bit of setting up.
Complicated stuff plumbing is ...
Ill keep this post updates with my "balancing" ;)
So yesterday i put lockshield in off position on one of the rad upstairs. This morning turned heating on and opened that lockshield just a little bit and extension rad is fully hot !
Hopefully not some kind of weird one-off coincidence and it will stay that way !
What are the ~ lockshield settings of all the rads, including the extension rad?.
Turned off all at lockshield except the extension rad, put heating on and couldnt get it all hot. Soooo annoying
