Large Timber Door Bowing - What's gone wrong?
Could do with some expert advice please to see if this can be remedied on a replacement.
The door is 1.1 meters wide approx, the construction is (I'm told) engineered hardwood solid core door (44mm) with 6mm tricoya face, the back is also faced with 6mm Tricoya (the inside face is white).
The 3 wide grooves running along the top are 6mm deep (so down to the hardwood door beneath the tricoya). The bottom lines are western red cedar which are glued into the same style grooves shown at the top. There are also grooves on the inside face the same depth but in a vertical direction.
The picture shows a gap at the top corner (it is also the same at the bottom, neither corners of the lock side touch the draft seals) the door was shut when this was taken so it's around a 5mm gap/bow at the top and bottom. This started to happen within 2 months of the install, is was end November at the time of installation.
The manufacturer is 'potentially' willing to replace it but can't say why it's happened and will not guarantee a replacement from doing it again.
The door has been in situ for a year now, the summer months get sunshine on this from 2pm onwards, in the summer it went flatter (not fully back but better than it is now)
It's a bit puzzling as to what's gone wrong and how it can be avoided.
Any thoughts?
TIA
Any thoughts?
TIA
