I have one of those cheap chinese volt pens, it is prone to giving false positives. I seldom use it because it is so unreliable. They often pick up inductive currents- your's lights up even when the switch is turned off, and displays more LEDs when the switch is turned on, it still doesn't mean that there is 230v running to the terminal blocks.
As others have said, you need, at a minimum, a cheap multimeter to check the voltage.
It might be a good idea to check the cables in the light switch. One would hope that the previous owners would have isolated the supply to the terminal blocks before moving out. There may be a switched/fused connection unit above a cupboard.
Oh, and never assume that the red is live and that the black is neutral.
BTW, I am not an electrician.
