We noticed this radiator wasn’t getting warm. Bled it and removed the TRV. The pin has less than 1mm travel even after applying 3in1 and jiggling it several times over the last week.
The pipe below does get warm now (before it was totally cold) so clearly there is some flow but nothing else does.
But the pin looks quite far out to me. I can’t push it in or pull it out, could there be a different failure/problem? Is it just a case of replacing the valve or can I try something more first?
