Hi
I'm planning the build of a garden room / office space which will be used year round. Therefore comfort will be a significant factor.
The building will not be subject to building regulations although I plan to have it conform to a traditional house build.
I have looked at 2 structural options as follows:
This will be a self build project so labour cost is not an issue for the building fabric.
Option 1: Rendered blockwork + 100mm insulated cavity + blockwork inner
Option 2: Composite clad timber frame + PIR insulation
Has anyone previous experience with considering the 2 options?
My garden backs onto an unused field with overgrowing bushes and weeds. The chosen options must be able to withstand this as well as extended periods of damp conditions (lack of sunlight in the area).
My cost comparisons shows the cost difference is negligible between the 2 build types in terms of materials.
Option 1
+ Traditional materials / building techniques (familiarity)
+ Heavier more "robust" building
+ Less maintenance.
+ 2 layers between inside & out; more = better?
- Larger foundations required to support the load
- Longer construction time
Option 2
+ Quicker build time
-1 layer between inside & out.
-Less able to install heavy shelving units
-Need to have a period if dry weather to ensure no damage to timber elements ie OSB boards
-Greater building shrinkage.
Experiences & data is much appreciated!
Regards
Option 1
+ Less maintenance.
Option 2
Regards
