Hey all. I don’t post on here so much these days due to a change in circumstances but just thought I’d share with you a picture of one of my most recent installations. Hope you enjoy! (This isn’t a wind up by way!)
Fly gallery? But clearly flies not in use with all those cables in the way
Hello, RF. Great to hear from you.Hey all. I don’t post on here so much these days due to a change in circumstances
It means different. There'd have been a bit more TRS plugged into the house dimmers and nowhere near as much data cabling around the place.What would that have looked like in the analogue days, or does the digital age mean more complex lighting options are now used
And I guess, while the power in each cable will be well below 16A, it would be complicated to introduce new lower power cabling in a safe and convenient manner.in practise if you can't get at the fittings fairly easily it is standard to have one power cable per unit
Remember these plugs don't have fuses in them so the whole circuit has to be rated to whatever MCB is in the distro. Loads easier to have every cable the same gauge so it doesn't matter which one you grab.And I guess, while the power in each cable will be well below 16A, it would be complicated to introduce new lower power cabling in a safe and convenient manner.
