Live looped at the switch, neutrals at lights.
28 Feb 2024
Single core live and earth looped in at switches and live coming back up from switch to turn lights on/off.
No neutrals in switches except some switched lives on two-way switches.
Single core neutral cable looped in at the light.
I have twin and earth cable. What's the best way to loop in additional lights as the lives and neutrals would need to be looped in at different locations?
Any advice?
Maybe some photos - are you sure they are neutral , colour does not mean neutral necessarily
can you loop in from the existing light and daisy chain , if they are all switched on with the same switch
I'm looking to add a new 1 gang switch and two lights.
I have attached pictures of a 1 gang switch and the light it turns on.
The black wires in the lights loop around the lights and appear to be neutrals (wired to neutral in light and live comes off a red wire at the switch).
Can we have more pictures of the switch wiring in particular showing where the earth wires(s) come from?
I have uploaded a couple more photos for the switch.
The earth wires seem to be from the single-core live and earth cables
To add more lights, you can only follow the same method by extending the Line(live) from the switches and Neutrals from the lights.
You could run a Neutral from an existing light to new switch and then to new light - or vice versa - if the locations made that easier.
@EFLImpudence The light looks to be in an accessible loft space. Could the OP identify the live feeds looped to the switches and insert a junction box with the looped neutral, then feed new switches and lights using T&E
Additional lights - where?
Please be aware that your lighting circuit needs RCD protection too
If the live loop is buried in the wall and terminations not accessible anywhere other than switches the thing I'd suggest is add a junction box to one of the live cables, It is possible that the cable running bottom left to top right for example.
EDIT: I've done it again, I started writing this reply before preparing lunch, in the mean time Derycks comment it probably easier to follow.
