Where can I get coil springs + can I repair this one?
  • Thread starter Thread starter OM2
  • Start date Start date
OM2
18 Jan 2007
We've got an Ikea bin. One of the coil springs has broken.
Can I get an exact duplicate from somewhere or can I somehow repair?
See pic below, I tried cutting a safety pin and was trying to somehow attach that to the broken end of the spring:
Is there someway I can weld/forge the 2 bits together without needing extreme temperatures!
Like some sort of glue? It would definitely work. I tried joining with some duct tape and it solved 25%... but nowhere near the full original.
This image shows the spring as it should be:
Hoping someone can suggest something!
In the meantime, I'll contact Ikea. They do happily send you spare screws and other things.
Problem is that they don't sell this bin anymore.
Thanks.
I think that is called a Torsion spring.
You can get them on ebay
The internal diameter is important
Some people charge several pounds for them. I dare say a spring supplier turns them out by the million.
I got some for a similar bin. If they are a loose fit they may fall off, so you may need to fabricate a retaining washer or lump of glue.
  • Thanks
Reactions: OM2
@John D brilliant!
Torsion spring fits the bill!
Very expensive though
I could buy and bend into place one part and cut short another part - but then it would be a waste if it doesn't work - either the spring will be too weak or too strong
EDIT: just saw some videos on youtube to make coil springs!
That would be super easy - just need to get the metal - not sure where to get the metal + some sort of metal with a notch cut in that I could use to make...?
All of this bother for a small coil spring!!
Rather than finding a bit of metal like a paper clip (won't work, too soft, you can bend it with our hands but you can't bend the spring with your hands) have you considered a small metal tube that you can slide over the remaining stub of spring? Something like a piece of copper brake pipe, then crimp it so it stays. Araldite or similar epoxy would help fill any gaps between spring and tube and inhibit movement that would work it loose
Yes, you could weld a bit back on but the heat would affect the springiness of the metal and it may end up bending permanently(because it's non-springy) at the weld point..
This might help with 'how to' -
I make a point of collecting any springs from things I intend throwing out, and put them in a drawer.
Keep them in a large crate, marked "stuff to be thrown away when I die"
Or perhaps the resident spring collectors @HarryBloomfield @johnny2007 could have offered to look through their vast collection and post a suitable match to OM2 ?
@OM2 if you want a short section of tube to try, PM me your address
