Help with well
10 Apr 2024
Hi all- looking for some advice if possible. I recently moved house (built circa 1770s) and there's a well in the garden. It's currently covered with wooden planks- underneath which there's some wire/half a metal cover. There's also a drainpipe that's running from my neighbours shed underneath the fence and into it.
I don't know really know where to start with this. I'm not interested in using the water but I'm open to the idea of putting a light & glass cover over the top.
Do I need to check the water quality?
Do I need to get the drainpipe removed?
Do I need to check the structure of the well itself?
How would I go about removing the metal towards the top?
Any help massively appreciated! Interested as to whether anyone know any business' that deal with renovating/repairing/tidying up old wells?
Cheers
I think any glass cover you put over that will get skanky and mouldy/ridden with condensation in no time.
If your gonna use the water then of course yes.
Where does it come from?
Are you going to get it removed?
Why would you want to remove it when your not going to use the water?
Drain pipe is just rainwater from neighbours shed.
If the well is structurally sound I'm thinking of making it a feature.
Want to get rid of the metal as it's ugly and like I say, thinking of making it a feature.
Well I don't see how you will ever prevent that on a wet well outside in the UK. Frosted glass I suppose would help to hide all that muck but rather defeats the object. Glass would need to take someone jumping on it you know that'd cost a fortune right?
Should surface water be directed into a well as it bypasses the natural filtration process as it percolate through the ground into the water table
