Well, that presumably depends upon the design - as I said, that sort of approach requires that the connections can be made 'from the front' (room-side) after the mirror has been fixed to the wall - and I'm far from sure that will necessarily always be the case
However, there are concepts such as "first fix", "making provision for possible ..." and "future-proofing" which require one to install wiring before one is actually sure what will be connected to it. What I am currently do comes into the category of "make provision for possible...".
Quite so, and no-one has been asked to do that. I had already decided to run a cable to roughly the place where an illuminated mirror might be installed in the future, and then make whatever modifications (to wiring and/or mirror) that may than prove necessary if/when a mirror is installed, and I merely asked a simple question relating to the likely amount of space that would be available in relation to the 'covering up' of the terminations of that wiring for the time being.
I have found this thread very enlightening. I am very rarely in a similar position to a person who comes here for the first time and asks a simple specific question. I think I can now understand why it's quite common that they 'never come back' to this forum again!.
