- Joined
- 20 May 2021
- Messages
- 120
- Reaction score
- 1
- Country
Hiya, someone has probably asked this question somewhere, but darned if I can find it when I need it.
Want to cut out a loft hatch hole in a new place on the ceiling to make it easier to access the loft.
Basically, can I cut this timber (think its a joist maybe) and so I can make the hole approx. as as indicated in the blue?
I would cut it where the red arrows are in order to make a hole indicated in the blue frame.
Is there anything I put in, to support this joist and then cut it? A frame around the loft hatch which connects it to the joists?
Those joists are about 5cm x10cm and they are about 40cm apart, seem to lying on the top of the brick walls which has that large beam as well that we are standing on.
This is without the blue frame and I assume that is just plasterboard ceiling I could cut through?
I am not touching any of the main beams or strut thingymajigs. Pic below of the loft area and where the new hatch hole would be in marked up in blue frame:
Video of the whole roof area:
https://photos.app.goo.gl/rf3YpuXPKNHAC6Dt9
Is there a standard size for large hatch hole (blue square which means I can buy a hatch hole cover off-shelf)? About 80cm x 80cm
Would welcome any insights as love to crack on with it tonight or tomorrow.
I assume I have to think about the space behind the loft hatch if a ladder is too be fitted on the hatch as well?
