Wet room enclosure, on tiled floor
24 Apr 2024
Duplicates merged
I have a small wetroom with curtains on a rail and would like to enclose the shower area until I can afford a total redesign of the room. Is it possible to install a sliding corner entry shower enclosure door cubicle direct onto the tiled floor, without using a shower tray? The one I’m considering is ‘ELEGANT 800 x 700 mm Sliding Corner Entry Shower Enclosure Door Cubicle’ from https://www.elegantshowers.co.uk/el...rner-entry-shower-enclosure-door-cubicle.html
Any advice or tips gratefully received.
I have a small wetroom with curtains on a rail and would like to enclose the shower area until I can afford a total redesign of the room. Could any plumbers advise me if it is possible to install a sliding corner entry shower enclosure door cubicle direct onto the tiled floor, without using a shower tray? The one I’m considering is ‘ELEGANT 800 x 700 mm Sliding Corner Entry Shower Enclosure Door Cubicle’ from https://www.elegantshowers.co.uk/el...rner-entry-shower-enclosure-door-cubicle.html
If the floor is level, sure. If it slopes to drain the water you'll need to do something - enclosure screens are installed on the level edge of a tray
Be sure to clean the existing tiles well; silicone won't adhere properly to tiles covered in conditioner etc
Thanks for this great point. Have my doubts about his level the floor is but will double-check.
