NZ Electrics (off topic content removed )
11 Jan 2004
Posting in Electrics UK, as I think the way Kiwi electrics are done will make an interesting comparison with ours.
This is one option the Kiwis have for doing sockets on cooker circuits:
One 10A socket on either side of the cooker.
In this case, the left hand one is powering the fridge, the right hand one the kettle.
This is a photo showing the kiwi twin and earth cable and aluminium buckle clips. This work was done in 1982.
Are/ were those sockets fused down inside the oven panel?
Buckle clips were what were used in the UK too, until around then - some might suggest they look neater, than the plastic nail on clips.
My dad was a spark and originally wired his garage using buckle clips with all the socket and lighting circuits neatly run on the roof timbers. I always thought it looked so much neater than what can be achieved using modern pastic clips. Later additions using plastic clips did not look quite as good
AIUI with AU/NZ plugs and sockets a smaller plug will fit a larger socket, so you can plug a regular 10A plug into a 32A socket, though my understanding is that such sockets are quite rare and watching some videos I get the impression that typical socket circuits there are 20A.
Ultimately, each country seems to find different things to obsess over, but overall each country seems to achieve a level of safety they consider acceptable.
IME, plastic cable clips started to appear between 1970-1974. But many used the buckle clips until much later. I personally prefer the plastic ones. They can look neat if you take your time and plan the routes.
plug:
Yes, I think you're right. I did see a larger outlet at the previous accommodation for a washing machine, but I forgot to take a piccy.
At out latest AirBnB:
An RCD socket the other side of the sink to the shower cubicle.
And what looks like a Manrose SELV fan over the shower tray.
A close up of the socket:
Yeah, it doesn't make much sense to me!
This is a good idea: a double socket with a third switch for a nearby appliance, in this case a waste disposal unit.
Glad it's not just me! I wonder if the average 'man in the street' in NZ understands?
Even the MIs aren't clear...
I believe (guess!), the indicators show the state of the socket and the second (additional) outlet - edit, in this case the fan.
Even the MIs aren't clear... <image>
My goodness! :)
I believe (guess!), the indicators show the state of the socket and the second (additional) outlet.
Who knows?!¬ Your guess may be right, but I'd put no money on it!
Do we know (or does a New Zealander know) what"A/P" is?
