Draper - certainly not the best but certainly not the worst. Not bad for its entry level price range IMO.
I do however groan when I order something from toolstation and then only discover it is Draper once they hand it to me.
That drill- it is the first SDS drill I have seen which uses a separate control to turn off the rotation.
Doesn't matter if you go a bit lower down, a couple of bends will soon drop the waste pipe from the trap outlet to the right level for going through the wall. I personally prefer to come through the wall lower down, it helps hide some of the pipework in the back of the cupboard, and means less visible outside.In terms of drilling the core, should I fit the new sink and trap first, find out where the hole needs to be and then drill it. I don't need to take into consideration any fall angle for the waste outflow?
for a rather small hole, does it matter?A proper core drill would be better than an SDS.
Hire Light Duty Dry Diamond Drill - 110V | HSS DIY
Hire a light-duty 110V dry diamond drill for clean, precise masonry core cutting on site. Get expert support from HSS DIY. Reserve online today nowwww.hss.com
Mcalpine stuff is much better. This would be my choiceOne of these would help:
The half sink pipe can be reduced to nearly nothing, so the whole lot would be a reasonable amount higher.
Thanks for your reply. I'm going to have a ring around the hire shops and check their prices, but looking online it's going to cost me over £100 for 24hr, which makes the think I'm best purchasing something, as I'll inevitably need it again.Mcalpine stuff is much better. This would be my choice
Makita 3 Function 800W SDS+ Rotary Hammer Drill
With its powerful performance and three modes of operation, this Makita SDS+ rotary hammer drill is perfect for a wide variety of jobs around the home and garden.The HR2630 drill is the successor to the popular HR2610 model, featuring a modified operation-mode change lever means you can switch...www.toolstation.com
If you do not have a drill machine, getting this one would be a safe bet as it has rotary action ( that is the ONLY mode you would employ for use when diamond tipped core is used) plus rotary hammer for drill in hard materials and rotary stop for breaking using chisels
Mexco Premium Slotted Dry Diamond Core Drill Bit
Cut clean and accurate holes in soft facing stone, bricks and blocks with this Mexco Premium Dry diamond core drill. High quality diamond segments and a welded, slotted barrel ensure all-round performance and fast waste removal.If you want to penetrate through a cavity wall without the need for...www.toolstation.com
Here is a core that you could buy but would also need adapters to fit above machine, hence it is suggested hiring might be better option. You are looking at spending upwards of £170 for equipment only
Trap by McAlpine is my choice as overflow is delayed as a blocked waste means the sink fill up. A standpipe allows the water to spill onto the floor which is quite common
Yes - but for what you need it to do and if you're only lightly using it then this would do as equally as well - if you think you may have the need to use it in the future.
Draper Storm Force SDS+ Rotary Hammer Drill, 900W
Features:• 3 functions - Drill, Hammer and Chisel• Safety clutch• Depth rod• Supplied with adjustable side handle, 2 x SDS+ chisels, 3 x SDS+ drill bits and 2.2m cable with BS Plug • No load speed 850rpm • Max impact rate 4100bpm • Impact joules 4J • Drilling capacity masonry 26mm • Drilling...www.toolstation.com
Minotaur Diamond Core Drill Bit Set
For fast, clean cutting and drilling in masonry, bricks or blocks, look no further than this Minotaur diamond core drill set. Supplied with accessories and a handy carry case, you'll be ready for a range of jobs – the kit includes 38mm, 52mm and 117mm diamond core drill bits suitable for wet and...www.toolstation.com
If you wouldn't use it again then hiring would be the cheapest, less wasteful, option
Is it really too high? Looks to me like someone's just made a "homemade" trap from some random fittings. Looks plenty of room below the wastes to fit a proper trap higher up rather than bashing holes through the wall.
In the image I took above, the waste pipe is as high as the first part of the trap. It was my understanding that if this is the case, the trap would be constantly full for the water to reach the waste outlet?
