- Joined
- 27 Jan 2008
- Messages
- 27,416
- Reaction score
- 3,310
- Location
- Country
No theseTHESE are the junctions in place at the moment whilst the room is being done....are these considered maintainance free?
are not maintenance free. Deep back boxes can house automation devices, be it a wifi connected switch, socket, or relay, so you can access them if there is a fault.I started with Energenie Mihome, it was a way around the problems of looking after a mother with dementia, and I took them with us to new house, so now some 8 years old,
I did expand on what I had, until they started to fail, of 5 smart light switches down to 2, and the 6 sockets down to 4, the 4 TRV heads down to 3 but that was down to carpet fitters. Moved to TP-link for light switches as they are battery powered so no problem with no neutral, the sockets moved to adaptors
if it fails, and touch wood non have to date, easy to replace. Only place I would consider using a wifi socket is the outside socket where no room under lid for an adaptor.Laying out a room is not easy, there are some options like dado trunking and lighting track to be able to move sockets and lights to suit, but in the main once the cables are in, there is little which can be done and keep to safe zones.
Wifi has changed the scene some what, a few years ago fitting cabinet lights in a room was in the main a waste of time and money, as they would in the main need one to walk around the room switching them on or off, to get all switches on one plate was rare, so they soon lost their appeal and I know mine rarely got switched on.
Today I walk into room with a cup of coffee in each hand and say hey google turn on living room light and they all turn on, and more to point time for bed and one command turns them all off. I use Google Nest Mini's but Alexa does the same. And in the kitchen being able to use voice commands when hands covered in flour has to be a good thing.
However it can get expensive, the display cabinet lights
were not bought all together, we got the centre one first from Lidi, and tried silly Ikea lights either side, which were not a success. I paid £25 each for lights either side and the centre Lidi ones were not much cheaper. A smart socket adaptor is £10 and it soon mounts up.Next is lighting track for kitchen, why, well lighting track allows one to get the lights to a new area with out it looking like an after thought, it is an after thought, but does not look like it. One could have power track all along the kitchen counter, plug in where ever you like, but it would be expensive, and all plugs would need changing so can't use items else where.
So the whole home is a compromise, be it lighting, sockets, central heating, I have one socket on my landing just above the book case, with a rechargeable touch plugged in, auto lights with power cut, and has built in PIR so lights at night when we pass it, but if I move the book case that socket will be an eye sore.
So you need to decide what compromise you will accept.
