Flat roof starting under soffit and fascia
12 Mar 2013
London
Hi Guys,
My flat roof on the extension will be starting under the soffit/fascia of the existing roof. Need to go as high as possible because of the ceiling height in the extension.
What is the best way to do this? Should I remove the gutter completely? Or just do it under the soffit?
Any advice is greatly appreciated
Under? Are you lowering the floor too? Or are your upstairs existing ceilings really high? Seems like a really bad detail. Ordinarily the wall plates would be at the same height, i.e. the flattie would hit the pitched, several courses of tiles up the roof.
You will need to remove the lower roof tiles, membrane, battens, soffit, gutter etc. Then as you build up the flat roof, fix OSB in place of the fascia and possibly a lay board up the rake of the roof also.
Thank you, I was going to lower the floor.
Do you, by chance, have a detail for the flat roof to pitched room transition?
Thank you.
I am doing this under Permitted Development. Is it ok, to connect flat roof into pitched under PD?
Yes, as long as you do not exceed any height parameters set out in the permissions criteria.
Have you had it designed or are you just winging it?
Had it designed, but the architect did not include any detail for that, only the cold roof detail. It says the the roof cannot be higher than 2800mm where it is closest to the neighbours fence.
Thank you.
Be careful. It is very difficult to get a flat roof extension on a bungalow under permitted development. The eaves height of the flat roof is usually higher than the eaves height of the existing pitched roof. (Under planning the "eaves height" is not what you would normally expect, from memory it is a notional line that intersects between the outer face of the wall and the upper surface of the roof).
For permitted development jobs I usually go with a false pitch - small pitched roof around the edge with a flat roof in the middle, that usually complies with the eaves height issue.
Thank you,
The eaves hight, according to the architect's drawings, should not exceed 2800mm where it is closest to the neighbour's fence. I will make sure it complies.
