Afternoon All,
We'd like to lay some engineered oak flooring in our entrance hall, but the current floor is the original 1930's parquet flooring that is far from level, or flat.
It's clear that I cannot just lay a levelling compound over the parquet flooring, so it looks like I need to lift it all up, and lay a concrete slab/screed in its place.
The thickness will vary, but will need to be about 20-30mm, over an area of about 10m2.
Is this too thin for a screed? If it is ok, what prep would you recommend before hand (e.g. primer) and what mix for the screed?
What alternatives do I have if it is too thin?
Appreciate any help you are able to give. Cheers, Adam
