- Joined
- 11 Jan 2004
- Messages
- 46,418
- Reaction score
- 3,744
- Country
Have had a problem today with a blocked gully.
Managed in the end to unblock it with the pressure washer.
But I was well confused about the drainage situation.
Our house has a manhole in the driveway at the front but this is only for rainwater.
The main sewer is at the rear, running through everyone's gardens around 2m from the back wall. There is a manhole in the garage which connects to our stack and next door's and runs to the main sewer in the back garden.
Confusingly, into the blocked drain feed two drainpipes and the condensate waste from the combi, along with the sink and DW wastes.
And a few feet away, there is a rodding point with an aluminium cover. I initially thought the blocked drain linked to the rodding point, but could not feel a T in the pipe.
I shoved 3m of rods down the rodding point. The rod seemed to go fairly straight towards the front of the building. It stopped at 3m, maybe due to a bend.
Then I focused on the drain, pulling out loads of lumps of mortar and then fatty goo. It felt like soft birds' fat balls (fnarr, fnarr!)
I could see there were bubbles when I did this, accompanied by a trickling noise, so I knew I was on the right path, but I could not reach far enough with my fingers to dislodge more goo.
That is when I admitted defeat and tried the pressure washer.
Before that, I was considering dismantling the pipework on the left hand side of the drain and looking underneath (the mortar was loose).
So, my questions are:
Where does the pipe from the rodding point go?
Does the blocked drain link to the sewer at the back?
The house was built in 1960ish. If that blocked drain is connected to the surface water drain at the front, I guess it's not to regs to have waste water emptying in it?
How do those "dual" drains work?
Do they have some kind of a trap built-in?
Here's the drain:
And the rodding point a few feet to the left:
And a diagram of the drains:
Here's the drain:
