the cable is 2.0mm twin flat 25 amp rated cable is here (no earth as the lights only have pos and neg for 12v) There is only one independant PIR. The lights themselves do not have a pir. The switch is this one illuminated switch. I have broken my multimeter but have one on order. Cheers
Current rating is not the only thing you need to take into consideration, when ordering cable, volts drop is equally important. It is especially important, where very low voltages are concerned, delivered over long lengths of wiring.
You have already stated you have used 2mm, which will suffer extreme volts drop, at 12v/20a, even over just a matter of a few feet. Post on here the actual measurements cable, between each light, and someone will surely work out the volts drop for you.
