- Joined
- 30 Jun 2024
- Messages
- 79
- Reaction score
- 30
- Country
1st post here, long time lurker. So I know that you cannot give gas-safe advice on the forum.
Long introduction before I get to the question - sorry.
Background: park home (basically a wooden bungalow) with above boiler installed (yes, I now know it is oversized) 10 years old.
Vertical flue (very short vertical flue).
Condensate pipe drops straight down under the home to join horizontal main waste pipe.
Runs on mains gas (NOT LPG). We have a water softener (also 10 years, also serviced each year).
Serviced every year under Baxi's own (now very expensive) maintenance plan.
Serviced in May, working all OK (electrode and seal replaced as part of service).
Next day, tried hot water - E133, Would not reset.
Since then, Baxi have been out 5 times (all under the service plan).
Tech 1 calibrated, said all OK, but it failed within 20 minutes, first time we turned on a hot tap (E133).
Tech 2 checked condensate pipe (from boiler end) said was clear, adjusted gas/air mix which removed E133, and it worked fine for 8 days, then started making SOMETIMES (not always) extremely strange and worrying rumbling and bangs on ignition before settling down and working quietly.
No error codes.
Hubby went up ladder to look at flue, pluming, no visible signs of any blockage.
Tech 3 managed to replicate the noise but could not find out why. Changed sensor and fan. Checked condensate pipe, said was clear.
Checked flue (from the boiler end) and said was fine.
Calibrated but would not complete (tried 3 times).
On last attempt E53 showed up. Tech said that was not possible, but left it anyway.
Next morning - E53 and lock out.
Tech 4 replaced gas valve and PCB, but turned boiler off as unsafe (not burning properly) while waiting for heat exchanger.
Tech no 6 replaced heat exchanger and was here for a very long time (about 3 hours) recalibrating and checking everything. Left it working very quietly.
That was 8 days ago - and guess what? E53.
It runs on either heating or hot water for about 10-15 minutes, all seems OK. Then flame symbol goes off and shortly after E53 appears on display.
BUT - turn off heating/hot water (whatever was running) E53 clears from display and then immediately turn on hot water and it fires up and runs for another 10 minutes or so before back to E53.
So - Question - finally:
Is it possible for either a flue to be intermittently blocked (one minute it is, next minute it isn't)
Or can E53 mean something else?
Calling Baxi out again tomorrow, but wondering whether to give up and start looking for an installer to replace.
Is this going to be fixable?
No error codes.
