Intercom Replacement Not Working
21 Jul 2024
Denmark
I Have replacent My intercom
Comlit Okay With Widex
Everythimg works except they cant hear me down on the street
I realize that you are writing in English - which is not your "Native Language" !
However, it may be that more information is required.
I believe that what you may have intended to write - in English - was as follows:-
"I have replaced my Comelit 5 Wire Okay Intercom
with a Videx 3000"
Further, the Photo 1 may have been the "original" situation -with the Comelit Intercom back-plate
and
Photo 2 is the way in which you have wired the Videx 3000.
The following is the way in which the wires of certain colours were connected previously to the "Okay" and the way in which are now connected to the Videx 411
VIDEX
411Okay
1Mikrofon Microphone3/6Black
2Hojjtler Speaker2White
3Faeles 0 Common (Earth)4Yellow
5Dorabner DoorOpener5Red
6Brummer Buzzer1Blue
This seems to be OK, except that it may be uncertain if some wires are now properly connected - particularly, the Yellow wire.
In your second Post it is stated
"can replace Carbon or Condenser microphone".
I am not sure that this should matter but
was the previous Microphone of either of these types?
The Model members of both of these devices may be of assistance.
Jeg er klar over, at du skriver på engelsk - hvilket ikke er dit "modersmål"!
Det kan dog være, at der er behov for flere oplysninger.
Jeg tror, at det du måske havde tænkt dig at skrive - på engelsk - var som følger:
"Jeg har udskiftet mit Comelit 5 Wire Okay Intercom
med en Videx 3000"
Yderligere kan Foto 1 have været den "originale" situation - med Comelit Intercom-bagpladen
og
Foto 2 er den måde, du har tilsluttet Videx 3000 på.
Følgende er den måde, hvorpå ledningerne i visse farver tidligere blev forbundet til "Okay", og den måde, hvorpå de nu er forbundet til Videx 411
Dette ser ud til at være OK, bortset fra at det kan være usikkert, om nogle ledninger nu er korrekt tilsluttet - især den gule ledning.
I dit andet indlæg står det
"kan erstatte kulstof- eller kondensatormikrofon".
Jeg er ikke sikker på, at dette skulle betyde noget, men
var den tidligere mikrofon af en af disse typer?
Modelmedlemmerne af begge disse enheder kan være til hjælp.
(Oversættelse af Google Translate. )
I have realized that Microphone and Speaker refer to the Equipment at the DoorOpener.
The Speaker wire (White) may not be properly connected to terminal 2 of the Videx (See Photo 2)
I suggest that you check this.
(In fact, check and improve all of those connections.)
Jeg har indset, at mikrofon og højttaler refererer til udstyret ved døråbneren.
Højttalerledningen (hvid) er muligvis ikke korrekt forbundet til terminal 2 på Videx (se billede 2)
Jeg foreslår, at du tjekker dette.
(Faktisk skal du kontrollere og forbedre alle disse forbindelser.)
