I'm doing a flat roof (brick and block cavity walls) and I'm reaching what is potentially the final course of bricks. I was planning to cut the last course of bricks at angles and then fix the OSB deck to them. I've realized that this will take a long time. I'm wondering whether I should use a timber firring for the last course instead? It'll be much easier and also make it easier to screw the OSB into.
The big drawback of timber is that it would increase the height of my fascia by 75+mm. That would leave me with 291 to cover with the fascia. So I would need to go with 400mm fascia instead of 250mm. I'm wondering whether cutting the bricks is a fools errand though. Should I just cut the bricks and stop worrying or is timber a better approach?
It would be very similar to what is in this video
