Hello,
I hope someone can please help.
We have moved into a 4 bed 1970s house with a 1970s /1980s ensuite that needs ripping out as it leaks and is past its best. It has a 30kw condensing gas boiler with hot water tank. My query is I want to ensure if we change the boiler for a heat source pump or electric boiler run by solar panels, which shower should we get, as I do not want to refit the shower in the future.
It currently has a quadrant cubicle but are changing it to a square cubicle. We plan to use multipanel for the wet walls, and hopefully east clean glass doors.
Should I get an electric shower, if so which wattage? Or should I do a mixer?
I assume the basin and toilet will be a straight swap other than the change from imperial to metric?
We want a good hot shower as my hubby has raynauds so struggles to get warm.
Aimee
Aimee
