Hi all, just wanted to get some peoples opinions.
A new customer of mine has asked me to look into what he can do about his heating system not heating up downstairs radiators sufficiently. He has recently had a extension and a new 32kw oil system boiler with 15-60 130 pump fitted outside. The system is quite large as a long house with ground floor and first floor and around 16 radiators average sizes with a unvented cylinder in loft.
The pipework from boiler goes up to the loft where it splits for the cylinder and radiators. I have been advised that the pipework feeding the radiators goes around like a loop (instead of dropping down multiple times to feed a number of radiators). This pipework is in 15mm and cannot be changed now. This means the radiators at end of the 'loop' downstairs struggle to get hot enough. The radiators have been balanced the best they can, while this has helped a little it hasn't solved the problem enough.
Due to the the pump being outside on ground level and having to be pumped up to loft before dropping down the rest of the house the customer is worried it is not big enough for the job and has asked me to install a bigger pump up the in the loft to boost the pressure. I understand the correct way of doing this would be to pipe correctly or fit a low loss header however the customer would like to try the cheaper option first of just installing the pump on its own.
I wanted to get your opinions on how this may work if at all and where the pump should be fitted. Do I install on the flow before the zone valves so it boosts flow to cylinder and CH or just on the flow after the CH zone valve? My concern if I install on just CH pipework is this will cause a issue with the cylinder being bypassed when both are calling for heat?
Many thanks Luke.
Many thanks Luke.
