Light Loop not receiving much Voltage
13 Aug 2024
Hi all,
The extension at our house has a double switch on the wall. One for the light and one for an extractor fan. The light and fan both stopped working at the same time (quite a while ago but been using a lamp in the meantime)
We are in the process of redecorating the room and I want to fix the light specifically.
I have replaced the switch and the light fixture but to no avail.
I have checked the old switch using multimeter and was working fine.
The wiring in the ceiling has 3 sets of wires (read previous threads for guides on this.) The switch wire was marked and I have tested this and verified with my multimeter. Having wired up nothing is working (the only difference to the diagram I saw was that the fixture I have doesn't have an earth connector so I just connect the three earths together, assume this is is OK?).
I have then checked the voltage across the wires and found there is little to no voltage there.
Wire 1. Live to neutral 0.81v. Live to earth 0.347v. neutral to earth 0.488v.
Wire 2. Live to neutral 0v. Live to earth 1.193v neutral to earth 1.193v
Switch wire on. Live to neutral 0v Live to earth 4.14v neutral to earth 4.14v
Switch wire off. Live to neutral 0.561v Live to earth 3.4v. neutral to earth 4v.
Am I doing something wrong is there an issue with the supply into the room?
Many thanks for any help and support.
Cheers,
Andrew
You could have a faulty live, neutral or earth or a couple of the above
Take extreme care is my advice
Are you sure your multimeter is set to measure AC volts and not DC volts?
Yes, was definitely AC.
Am I in the realms of needing to call a professional here or is there anything more I can do?
Do you know where the extension is fed from, sometimes small extension lights are supplied via a 5amp fuse off the socket circuit
If not already done so, measure some AC volts elsewhere to make sure your meter is working correctly.
