Please advise on this wiring
23 Jan 2003
Please advise on this theory........this is a radial circuit to shower room converted from garage.......wiring in pull switch from 5A fcu to pull switch: live to terminal A, earth to earth terminal in base and neutral terminated in choc block .........wiring from pullcord to light: earth to earth in terminal base, live from pull switch terminal B and neutral terminated in choc block .........wiring in light: live to live terminal, earth to earth terminal (if there is one) and neutral terminated in choc block........wiring in extractor fan live to live terminal....earth to earth terminal (if there is one) andneutral terminated in choc block.
lol nice mate should be all good to go :) make sure them earths are conneted properly thou :D
It will work better if in your light fitting and extractor fan you connect the neutral wires to the neutral terminal, rather than terminating the wire in choc-block
