Hi everyone.
Doing a DIY kitchen refit and currently I only have a single 2-gang socket!
(Small kitchen but that's not enough!)
Just wanted to check if there's any words of advice on my plan below or if I've got it horribly wrong.
1) Add 2-gang DP socket by extending the ring final as pictured.
It's close enough to the existing socket that I can connect the existing cable straight to it.
It will be above the wall units to power an extractor hood and some LED cabinet lights with 3-pin fused plugs.
2) Spur off the new socket, for a 1-gang socket near the fridge.
This is so the fridge's cable doesn't need to go behind/across the cooker!
3) All cables and sockets are currently surface mounted. For the existing countertop socket, I want to sink it into the wall so plan to chase a channel vertically for the existing cables and feed them through an oval conduit, then plaster over. I'll leave the rest surface mounted as they are generally out of sight or use existing trunking.
I'm not planning on touching the 32A cooker circuit and control unit (the one with red switch).
robato
robato
