So what is the problem? If you understand it, and can direct your plumber - surely, that is all that is needed?
Do you really think a Welsh plumber would understand how the Willis system works? Hard enough to find one who knows how central heating works. At least the one doing my central heating admitted he did not know how to wire it, which for me was no problem as I did. But can see why it was in such a mess when I moved in, as finding any one who can do things out of the normal is hard, getting trees cut down, easy, fencing also easy they turn up with tractor and post hole auger and fences all done in very short time, but plumbing and central heating, I noted the sticker on boiler, and clearly was not going to use them. Why would you admit to poor workmanship?
I decided to see what difference it might make, by adding an old winter bed duvet over the cylinder.
My airing cupboard is stuffed full, hate opening the door, as it all falls out, so would not think much heat escapes.
I looked at cost of heating 120 litres, around 8.5 kWh so it would cost at 31.31p per kWh around £2.70, however today 11:20 am the iboost+ says water tank hot, so thermostat has switched off, and I have used 0.25 kWh at no cost to me anyway, as not paid for export, but even if it was costing, it would have cost 7.83p at most. Now to use oil the boiler runs for 20 minutes 4 times a week, at 20 kW so 3.8 kWh per day, as a 20 kW boiler, so to break even the oil needs to be 15 times cheaper, as said the distance boiler to storage tank will make a difference, but the big problem is although these
are easy to use, immersion heaters tend not to have a plug and socket, so the shower, immersion heater, and cooker, are the three items in our homes which we can't easy monitor power use, and it was not until the iboost+ was fitted that I had any way to measure the power used by the immersion heater.
Same with oven, an air frier is basic a small fan oven, likely cheaper to use than a large oven, a microwave tends to be using power all the time it is on, where air frier and ovens switch on/off once hot with a mark/space ratio, to compare needs to cook same food, never tried to do a baked potato in air frier, normally start in micro wave the transfer to oven with the pizza, air frier not big enough to do a pizza in, so considering will be using oven for pizza, is it really worth (other than speed) starting the baked potatoes in the microwave? Measuring watt, or amps is easy, measuring on time is not with items not using a 13 amp plug.
So we read what others have said, again if my boiler was gas, it would likely modulate, so for the boiler to run for an hour, tells us nothing, as it may be anywhere between 6 and 28 kW, but my oil boiler is simply on/off, so if it runs for 20 minutes and its a 18 kW boiler, then easy 6 kW has been used. Actually 20 kW and normally slightly over 20 minutes run time, and the water is a bit on the cool side, but we have some idea at least of energy used.
Smart meters are about as good as a chocolate fire guard, as they measure whole house, so freezers etc are cutting in and out, and only work when no sun, as the export figure tells us nothing as to what the home is using, and the solar software has a delay, I can view this
and see the sun disappear behind a cloud, but change is some 15 minutes latter, big problem some info relied by server in china, and some direct, so view totals for day and reasonably accurate, but I can make a cup of coffee, and come upstairs, and the spike due to making coffee has still not shown.
So not seen any replies from some one who can measure the energy used in the way I can as yet, calculations are no good, need some way to actually measure the energy.
