Terrecotta tiles onto limecrete NIGHTMARE!
27 Dec 2006
London
Very porous tiles, and very porous floor! Tried every combination of sharp sand, builders sand and NHL5.
Won't spread, won't stick, absolute nightmare!
Have you primed both the floor and tiles before laying?
I havnt tried any primer - I understood that would prevent the floor from 'breathing'.... It's a new limecrete slab on glass foam insulation.
Possibly so, but covering the floor with tiles will surely affect the breathability... are the tiles stone or ceramic?
If you used Ncl5 for your lime crete it will loose most if not all of its breathability as it cures.
Adhere-vit is probably product for you....Did you lay the limecrete over foamed glass aggregate?
https://www.lime.org.uk/adhere-vit.html
Not come across that one. Yes, the more I've read about NHL5, the more I think I'll prob do cement next time - still on the foamed glass though.....
I've got the tiles to work using a NHL mortar.... It was all about controlling the suction of both floor and tile.
Here's what's working :
Wet floor with masonary paintbrush, not too much... then paint floor with a lime slurry. Spread 2:1 building sand /nhl5 onto floor with notched trowel. Soak tile in bucket of water for 10-15 seconds, back butter tile with the mortar. Press tile firmly into place.
Then grout with 3:1 sharp sand /nhl2
I've done about a square metre, only 15 to go.....
Foamed glass acts as damp/moisture control and thermal insulation to acceptable building standards u value.
