Hi everyone,
I'm back again needing some advice on my extension roof. We've got a felt cold roof installed, but the firing strips are too short, leading to an inadequate slope and water pooling.
Initially, I thought adding a channel at the edge would drain the water into the gutters, but one roofer thinks this won't work and suggests overboarding with EPDM.
This essentially means building a new roof on top of the existing felt, which would leave the felt roof acting as a vapor barrier, but the cost is around £3.5-4k.
I'm a bit confused about the best solution here:
- Would a channel actually be effective in addressing the pooling issue, or is it a temporary fix at best?
- Is overboarding with EPDM the only long-term solution?
- Are there other options to improve the drainage without completely rebuilding the roof?
Any thoughts or experiences you guys have would be greatly appreciated!
I've attached a couple of photos to give you a better idea of the situation:
